02-24-2023
20:14
04:52
DavideFitbit
02-24-2023
20:14
04:52
DavideFitbit
Suddenly my Charge 5 won't hold a charge for even an entire day. I've charged it to 109% TWICE today. What the heck!@
02-25-2023
04:52
11:40
02-25-2023
04:52
11:40
Hi, welcome to the Fitbit Community forums, @Picard321.
I appreciate all this information that you've shared about the inconvenience that you've been having with your Charge 5.
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
Best Answer02-25-2023 17:34
02-25-2023 17:34
Best Answer02-25-2023 17:54
02-25-2023 17:54
Just noticed same thing happened to my fitbit too. battery was fully charged last night and went down to 13% about an hour ago. I charged it to about 40%, then walked around for 10 min and the battery drained to 14%. I plugged into the charger and push the button 3x, but battery went down to 4%. it's currently charging now. FYI, it's my 2nd fitbit charge 5. first one died after 6 months when it would not charge at all.
02-25-2023 18:13
02-25-2023 18:13
19:40
06:06
DavideFitbit
02-25-2023
19:40
06:06
DavideFitbit
Yes, they replaced it. I got the current one (the replacement) around Sept/Oct last year.
Okay, I must have the worst of luck. I just charged charge 5 to 99% and wore it for like 10 min (sitting & typing) and battery is down to 70%.
meanwhile, I figure I can switch to my backup Inspire 2 and it won't get pass "download Fitbit app" during the setup. both ios and Fitbit were updated today. Is this a fitbit server problem or what's going on?
Best Answer02-25-2023 20:13
02-25-2023 20:13
Best Answer02-25-2023 20:17
02-25-2023 20:17
well i was able to finally set up my back up insprie. at least the tech support was able to help me. I had to restore it factory setting.
Best Answer02-25-2023 20:29
02-25-2023 20:29
Best Answer02-25-2023 21:03
02-25-2023 21:03
let us know if it actually solves the charge 5 battery problem. for now i am going to go back to inspire 2.
Best Answer02-26-2023 11:43
02-26-2023 11:43
I bought my Fitbit charge 5 in November 2023 so it's only 3 months old. It was working well until last week when it suddenly would not hold its charge, it goes from 100% to nothing within a few hours.
I have deleted ther Sp02 app and followed the steps you suggested in your last post.
Reading all the posts this seems to be a problem associated with this model.
Any help beyond this would be appreciated, failing all I would hope for a replacement.
Best Answer02-26-2023 13:22
02-26-2023 13:22
Best Answer02-26-2023 14:22
02-26-2023 14:22
No luck for me either. This morning, charge 5 battery was down to 3% (fully charged last night). I charged it to 99% and left it in my desk drawer for most of the dead. Now it's down to 2%.
I bought my charge 5 Feb 2022. around Aug 2022, it suddenly stopped charging then went dead. Fitbit sent me a replacement around Sept 2022. Now after 4/5 months, the replacement is having issue. I think this is probably a hardware problem that hasn't been addressed. Mine is out of warranty. even if fitbit were to offer me another replacement, I am not sure it will survive more than a few months.
Best Answer02-26-2023 15:15
02-26-2023 15:15
Best Answer02-26-2023 19:04
02-26-2023 19:04
Best Answer02-27-2023 12:52
02-27-2023 12:52
Best Answer02-27-2023 17:25
02-27-2023 17:25
Best Answer02-27-2023 18:49
02-27-2023 18:49
That’s great it’s working for you again. No luck for me either. After I saw your post, I charged mine to 70% but then it went down to 2% after 30 min. Did you update to the most recent firmware? Some on the forum suggested all the problems were caused by the firmware update and the trick is not to update firmware. I never updated the firmware for my replacement, and I wonder if I should.
Best Answer02-27-2023 19:47
02-27-2023 19:47
Best Answer03-02-2023 08:47
03-02-2023 08:47
Fitbit ibviously have a software/hardware problem from latest update. I have same issue for the past few days. Why can they not accept problem and sort things out. My wife bought another make 14 months ago at less than 20% of the Fitbit 5 price and has had no problems. Hers seems to have all the basic apps etc that most would need I also had no charging issues till a few days ago. Now total discharge in a few hours. Dreadful! I chatted with them electronically but got nowhere and was eventually cut off. Abominable service.
Not a fan!
