11-08-2022
21:51
06:00
DavideFitbit
11-08-2022
21:51
06:00
DavideFitbit
Hi there,
it seems like I’m not the only one who has battery drain issue with Charge 5 and clearly also not the worst case based on some of the existing topics on it. My Charge 5 is less than a month old and it would only last for about 4-5 days with a full charge ever since I received it.
The battery is supposed to last 7 days with a full charge, which is the same as my old Charge 3. I’ve never had any battery issue like this with Charge 3. Please advice how this issue could be resolved.
many thanks for your attention to this matter in advance.
Moderator edit: format
11-11-2022
05:59
07:19
11-11-2022
05:59
07:19
Hi, welcome to the Fitbit Community forums, @Delphinus.
I appreciate all the information that you've shared about the inconvenience you've been having with your Charge 5 and for confirming that you already tried a few troubleshooting steps.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've provided you with some instructions. In this case, they will let you know how to proceed.
Let me know if you continue to experience the same problem after the steps suggested.
I'll be around.
11-11-2022 07:09
11-11-2022 07:09
Hi Davide,
thank you very much for your reply!
in addition to the battery problem, the GPS on my Fitbit has never worked either. Unlike my old charge 3, I have never seen a map showing my walk or run on my Fitbit app ever since I changed to charge 5. The GPS on my charge 5 have been on dynamic since I set it up.
After my call with customer service, I was told to observe it for a few more days. As the problems persist, I’m unclear what the next step should be. Do I have to call customer service again?
Thank you again for your help!
have a good day!
Estelle
11-26-2022
08:37
07:18
11-26-2022
08:37
07:18
Hi, thank you for sharing this information about the trouble you've been experiencing with your Charge 5, @Delphinus.
If the GPS is getting disconnected during your activity, the Charge 5 may track different information for the the distance. Before considering other options, make sure to follow the steps suggested in this article.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. In particular, please make sure of the following:
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed in this article to complete a restart, as this has been useful for other users experiencing something similar.
In case the problem is related to the app not showing you the map, please follow these steps as well:
I'll be around.
01-11-2023 20:18
01-11-2023 20:18
Hi David,
Happy New Year!
I'd like to follow up on my post as it's been a few months since we spoke about the battery and GPS issues.
I have tried what you suggested above numerous times but my Charge 5 battery consistently only lasts for 4-5 days, instead of 7. GPS never worked, not even once.
As the GPS never worked, I don't believe the battery drain is related to the GPS usage.
As I mentioned previously that I had 2 Charge 3 and the GPS functions on both of them worked well, I'm familiar with the GPS function on Fitbits. It is not normal that the GPS function has not worked once ever since I have this device.
Any feedback would be appreciated.
Best regards,
Estelle
01-21-2023
07:56
07:18
01-21-2023
07:56
07:18
@Delphinus Thanks for sharing your reply.
The GPS feature would actually make the battery drain in just a few hours if it stays activated, but there are other features that also consume battery:
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
01-21-2023 22:35
01-21-2023 22:35
02-03-2023
07:04
07:18
02-03-2023
07:04
07:18
@Delphinus Thank you for sharing that you're still having this inconvenience with the Charge 5.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Please keep an eye on your inbox.
Have a good day.
02-03-2023 07:40
02-03-2023 07:40
02-04-2023
04:36
07:18
02-04-2023
04:36
07:18
@Delphinus No problem!
Have a great day.
