09-13-2023 15:48
09-13-2023 15:48
My fitbit after 1.5 years running ok suddenly I am having trouble waking it up and it needs charging every day. I’ve changed to “dim” turned “always on” to off, reset it via the cable. What else can I do?I’ve tried everything it says and it still is not fixed. It appears to be a battery issue and since I’m in Australia the warranty only lasts a year, unlike Europe. Can you get a new battery for a Fitbit device?
09-13-2023 16:26
09-13-2023 16:26
Good to see you participating in the community @Yve_ke.
Thanks for providing all the details regarding this inconvenience, I'm sorry to know about it.
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
If you're trying to get in touch with the Customer Support team, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
09-14-2023 13:49
09-14-2023 13:49
Hello @Yve_ke
One of the users has a detailed post explaining what they did for the rapid battery drain: Possible fix for Charge 5 rapid battery drain
Hopefully, their tips might help you.
09-15-2023 05:35
