Hello! I'm a newbie with a Charge 5 and Fitbits in general, so I have a few simple questions:
Welcome to the forums @AJA61
Fitbit can automatically detect some activities, that can be configured in your settings. You can add specific activities to your tracker and start a workout (run, walk, "workout", elliptical, etc) from your tracker.
https://help.fitbit.com/articles/en_US/Help_article/1935.htm
See this article on sleep. Nothing to do, but wear the tracker to bed, and get a good night's rest. You can set your normal sleep hours, if desired, and get a notification that it's bedtime.
https://help.fitbit.com/articles/en_US/Help_article/1314.htm?Highlight=sleep
I would use a soft cloth, or a cloth for cleaning glasses. Once or twice a year I remove the watch band from the tracker and use an old toothbrush to clean out the jun that accumulates in the band latching mechanism.
Good luck and I hope you enjoy your fitbit.
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
The easiest way I have found to continue to track different exercises that are not automatically detected is to go ahead and start a Workout exercise on your Fitbit, do the exercise, and then stop the Workout. When it loads into your phone app, find the Workout in the Track Your Exercise tab, open it, and select the edit pencil. This will allow you to select what the exercise was from a large pull-down menu and save it. Enjoy!
Thanks! I used that suggestion for a workout with a rowing machine, since rowing wasn't an exercise option. Did it as a "workout", then changed it to "rowing" under the edit options.
