01-03-2023
15:17
10:01
01-03-2023
15:17
10:01
My Fitbit Charge 5 drains while im sleeping even though before this issue the drain was only 1% while now the drain from night to day is 75%. I have tried all the methods below and all of them had not worked. Please help.
P.S I have noticed that battery drain is a common issue for Fitbit devices, I had a charge 2 before this and the battery drained so fast that I bought this, but now this is giving me the same result 😑😔
Moderator edit: format
09:25
10:00
01-05-2023
09:25
10:00
Hi, I appreciate the information provided about this inconvenience with your Charge 5, @runner165.
Thank you for sharing that you've been having this inconvenience with your Charge 5 and for confirming that you already tried a few troubleshooting steps.
Since you already tried the steps that are usually helpful with these type of issues, I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon.
See you around in the Community.
Thank you for sharing this David. I got my Fitbit watch for Christmas. That means I've only had it for 2 weeks. I never have drainage issues or things like that happen but the night before last I woke up in the middle of the night and my watch was off. It was at 82% when I went to sleep. I was shocked because I had not seen a fast drain on it before. I thought maybe I accidentally turned it off while I'm sleeping but I couldn't turn it back on. I put it back on the charger and the battery was completely dead. The watch has never done it after or before and I have no idea what happened. It kind of freaked me out. I'm a runner and I went running that evening so I don't know if that had something to do with it or not. Thank you for sharing. Last night when I was sleeping I had no battery drained so I'm not exactly sure what happened. Hopefully it doesn't happen anymore but I bought insurance on my watch and I'm a premium member.
Best AnswerI haven't got an reply from the customer support team for more than a week, My fitbit still has this issue. Even with all the options of to save battery like switching off always on display I still get only a day which is completely different from the advertised 7 days
08:54
10:01
01-27-2023
08:54
10:01
@Tvanlengen1 Thanks for taking the time to share your experience with this. Let me know if you continue to experience the same problem with the battery or if it happened just this one time. Keep in mind that some of the feature that can drain the battery more rapidly are:
You can find other recommendations to extend battery life in this article.
@runner165 It seems the Support had sent you a response via e-mail. Could you please check if your spam folder as well if you've received it?
