01-14-2023
18:15
05:44
DavideFitbit
01-14-2023
18:15
05:44
DavideFitbit
I accidentally deleted the charge five on the website dashboard. The Fitbit app does not have the charge 5 listed any more. I told Bluetooth to forget the Charge 5 but it sill auto connects before I can set it up as a new device.
Moderator edit: format
01-18-2023 05:43
01-18-2023 05:43
Welcome to the Fitbit Community forums, @Beckiej.
I appreciate the information provided about this inconvenience with your Charge 5.
Could you please confirm what is the version of the operating system running in your phone? In the meantime, make sure to check the compatibility requirements listed here.
You can also try uninstalling and reinstalling the app to check if you see the Charge 5 listed.
See you around.
01-18-2023 18:04
01-18-2023 18:04
I deleted all of the unused Bluetooth devices from the Apple menu and then try it again and it worked
01-28-2023 09:22 - edited 01-28-2023 09:22
