06-09-2024
08:53
11:13
LizzyFitbit
06-09-2024
08:53
11:13
LizzyFitbit
I no longer see a way to set “hike” as a shortcut. Also, when I set them on my app, my phone is not recognizing them. I’ve restarted my Fitbit and re-synced several times.
06-09-2024 10:21
06-09-2024 10:21
Hi @Arkhikr and welcome to the Community. Can you give us more details, please? What model Fitbit do you use? Where are you looking for the shortcut, on the device or in the Fitbit app?
Laurie | Maryland
06-09-2024 10:31
06-09-2024 10:31
06-09-2024 12:59
06-09-2024 12:59
@Arkhikr I moved your post to the Charge 5 forum, a better fit for your question. I don't have recent experience with the Charge. I know there was a firmware update that put all the shortcuts on the device in the Exercise app. That firmware version is 194.91. You can check your firmware version by tapping on the device/battery icon in the upper left of your app, then your Charge 5 tile. There are 20 or so exercise shortcuts, mostly in alphabetical order.
If this doesn't help you, I hope another Charge 5 user can help you.
Laurie | Maryland
06-09-2024 13:29
06-09-2024 13:29
Hello @Arkhikr
I believe that one of the firmware updates changed the way that the Exercise shortcuts work on the Charge 5. Instead of setting up exercise shortcuts, your most recently activities will show up first in the Exercise tile. I don't recall how many recent activities are available with the Charge 5, but it should be at least 3.
This means you will need to scroll and select Hike as your activity and complete the session. Then the next time you open the Exercise tile, you should see Hike at the top of the list.
06-09-2024 13:34
06-09-2024 13:34
Thank you. I have always used hike for my activity, but when I go to the activity list now, I don’t see it listed.
06-09-2024 13:40
06-09-2024 13:40
I found out what the problem was. It will only allow you to list five activities, so I had to delete some to allow me to choose from the bigger list. Thank you all for your help!
06-09-2024 13:56
06-09-2024 13:56
Hello @Arkhikr
Thank you for letting us know that you figured out the issue with your shortcuts and you were able to set it up the way you want.
06-09-2024 14:32
06-09-2024 14:32
06-10-2024 04:55
06-10-2024 04:55
@Arkhikr Version 194.91 was released in Dec 2023. Users get notified of an update in the app. Tap on your device/battery > Charge 5 tile. Users get a pink Update option when one is available. Please contact Support if you can't get the update.
Laurie | Maryland
06-10-2024 08:36
06-10-2024 08:36
06-10-2024 11:00 - edited 06-10-2024 11:01
Hello @Arkhikr
As best as I can tell, the rollout for Charge 5 firmware Version 194.91 may have been halted. My Charge 5 is on the same firmware version as yours.
06-10-2024 12:42
06-10-2024 12:42
