Hello @deniray ,
If you go into the Today screen on the App on your phone, then tap your Profile, then App Settings, then Time Zone, you can check if you've entered your correct country there. If you haven't, you can change it. Then sync your Charge 5, and the time should correct itself.
I hope that helps.
