fitbit charge 5
How do I set up the Sp02 on my fitbit? Everything else is working except that. Being an oxygen user, this is the one feature I really wanted.
1 REPLY 1
Hello @Snootie1 ,
Do you have SpO2 on your phone App and watch?  You can check the App by tapping on Today, your Profile picture, Charge 5, Gallery, then Apps.  That should show you a list of Apps on your account.
If it's not there, check the list at the bottom of the page to check that it's available in your country:
SPO2 Country List
If it is available there, check for updates for the App and your Charge 5.
The SpO2 only tracks the levels when you're asleep for more than 3 hours and will show up after a few nights usually.  In the morning it will usually turn up after a slight delay.  The non-premium version isn't very detailed - it just gives a percentage and you can numbers for the last week.
I hope that helps a bit.
