11-13-2021 08:00 - edited 11-13-2021 08:02
Nevermind. Problem solved. Not sure how to delete this 😞
Best Answer11-13-2021 08:04
01-18-2022 23:56
01-18-2022 23:56
Could you share the solution for people like me who came here from Googling? 🙂
Best Answer01-19-2022 00:14
01-19-2022 00:14
Hello @napo2k
You can change your language from the App on your phone. Start from the Today page, tap your profile picture, then App Settings. Tap on Location and choose the country with the language you would prefer. Save then sync your Charge 5. You may need to put it on the charger to do an update to the new language.
I hope that helps.
