08-25-2023 04:20
08-25-2023 04:20
I had the charge 3, which was well past its sell by date, the screen was facing and I was unable to read on it. I learned I can put notifications on it from the apps on my phone. I was currently getting updates from my libre sensor reading my sugar level which I was ever so pleased about.
I went away and purchased the 5 so I could then see the screen properly and my sugar level results however now I'm not getting notifications from my libre sensor to my new fitbit charge 5.
Can someone help?
08-25-2023 14:01
08-25-2023 14:01
Hello @Nicoledeex
Have you checked to confirm that the Libre Sensor app has been set up in your list of apps for notification? Here are steps if you need them:
If the Libre Sensor app was in the list, then you should start getting notifications from the app. If you're still not getting notifications, then try unselecting, syncing, re-select, and sync again. Hopefully, this will be successful so you get the notifications on your device.
