Morning. It's been a tough year, so in an effort to ramp up my self care and motivation I ordered myself a FB Charge 5.
I charged it and put if on at around 4pm last night and I noticed when I went to the loo in the night that it seemed dead. Just one of a few visits.... gives you an idea of my age 😉 I have all the settings tweaked, as suggested in other battery related posts on this forum and I am recharging it at this moment.
What is the consensus from fellow users? Do I send it back today or persevere (really don't need any more hassle at the moment). Is it miraculously going to improve?
Best AnswerHi Karmajules,
as a long time Charge user (owned Charge 2,3,4 and 5), i suggest you return it while the return window is open. i returned mine and use Charge 4 now until they come up with a fix for battery drainage issue. if you still like FB and want to stick with Charge, then get any of the older models Charge 2,3 or 4 as they are pretty stable. and have longer battery. if you are after the ECG, try Withings Hybrid Smartwatch. it has 4 weeks battery and analog/classic look. hope you find this helpful. stay safe
Owaida
Best AnswerOwaida
Many thanks for your reply, I appreciate your advice and experience with Charge 5.
Packing it up now!
Thanks you
Julia
