12-01-2025
03:26
05:23
HorareyFitbit
12-01-2025
03:26
05:23
HorareyFitbit
The charge on my fitbit seems to go down very quickly now, I've had to put charge it every day
Hi @Lindamos is nice to see you again around the Community!
Let me tell you that i moved your post from the previous thread since it was a different topic and for me to be able to adress your situation in a better way I created this new one,
Regarding your situation with your battery draining quickly I can recommend you this following article for you to be able to improve your situation. Extend your Fitbit device's battery life in the section of ¨Tips to extend your Fitbit device's battery life¨.
Hi @Lindamos, is nice to see you around the Commuunity!
Since the steps provided by the community doesn´t seemed to work for your specific case I recommend you to contact our Support team since they have more tools that might be helpful for your situation.
In the following link you will have to describe your situation and you will recieve some recommended articles, after that you will be able to choose how you want to contact our team. Support
