11-30-2021 07:41
11-30-2021 07:41
I got a Charge 5 a two days back hoping to get more battery than my Galaxy watch active. To my surprise, the battery drained quite fast on 1 day. I charged it again to 100% and the battery drained fully within 24 hours. I am using default settings and did not track any exercise/GPS etc.I had used so many fitbit's over few years and none had such a pathetic battery life. Any suggestions?
11-30-2021 07:44
11-30-2021 07:44
Hi @vishalw two days isn't long enough to get used to all the bells and whistles of a new Fitbit. Read this article on how to extend the battery and if this doesn't help, you'll need to get with support.
11-30-2021 10:34
11-30-2021 10:38
11-30-2021 10:38
Thanks @Odyssey13 . I had already gone thru the article that you shared above. I am using Charge 5 with default settings. So far no GPS usage. It is lasting only 1 day and not even 2. I had used several fitbit over last few years and still has Charge 4 and 1st gen Versa. None had this issue. I purchased Charge 5 mainly for battery life as I did not want to charge my Smart Watch every 1.5 -2 days (Galaxy Watch Active). I have been trying to reach out to fitbit support via chat and the page is no more available.
11-30-2021 10:39
11-30-2021 10:39
https://myhelp.fitbit.com/s/support?language=en_US
Best Answer12-01-2021 17:42
12-01-2021 17:42
Update,
My Charge 5 drained fully at night.i recharged it and somehow the battery life was extended to more than 1.5 days. It died again and I am recharging it now. I will check the battery life again. If it is still bad then I plan on returning it.
12-02-2021 05:55
12-02-2021 05:55
Welcome to the Community forums, @vishalw.
Thank you for sharing that you've been experiencing this inconvenience with your Charge 5.
In this case, if you already tried the all the steps suggested and you continue to experience the same inconvenience with the battery draining too fast, I recommend that you get in touch with the Customer Support team for further assistance. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a good day.
12-02-2021 20:07
12-02-2021 20:07
I'm so disappointed with how awful the battery life is. I too only get a day per charge, and I've tried the troubleshooting in the article and it actually made it worse (I originally got 1.5 days). I need to contact support to figure out a return.
12-02-2021 20:21
12-02-2021 20:21
UPDATE:
The battery almost died (~3%) in less than 24 hours. I contacted support via phone as somehow the chat support was not working. I talked to the support person who took details like email and "checked something in the background". Eventually he told me that my case has been escalated to a different team and they will contact me via email in next 24 hours. Waiting for email...
12-02-2021 20:51
12-02-2021 20:51
@vishalw @TactfullyBlunt can you both check something is your GPS set to Dynamic that would be the best GPS setting as its not relying on the fitbit gps you both may have already tried it but its worth saying.
Best Answer12-02-2021 21:12
12-02-2021 21:12
@GuardianSean- GPS was/is set to Dynamic. The tracker is running all default settings. No Always On either.
Best Answer12-02-2021 21:15
12-02-2021 21:15
@vishalwokay that in my opinion would be the biggest culprit outside of always on for battery drain that i know of.
02:16
05:56
DavideFitbit
12-03-2021
02:16
05:56
DavideFitbit
I have tried both your suggestions and neither one works.
Me too!
12-03-2021 02:25
12-03-2021 02:25
Support hasn't been much help. They told me to let the battery drain, charge it back up and then contact them again if it didn't hold a charge. This is ridiculous.
12-04-2021 15:05
12-04-2021 15:05
I did not get any response from support so far. The Charge 5 died again last night. If the support response is going to be, let the battery drain and recharge, then I had already tried that two times. Looks like a faulty product. I am returning it soon. Going back to Samsung Galaxy Watch Active 2
12-04-2021 15:19
12-04-2021 15:19
@vishalw It sounds like you have a faulty battery. My Charge 5 lasts 5+ days. I would return yours or exchange it. Draining in one or two days is not normal behavior.
12-04-2021
19:59
05:57
DavideFitbit
12-04-2021
19:59
05:57
DavideFitbit
Update:
I got a replacement unit. I will test it and share the experience soon.
Battery down from 100% -> 81 % in ~55 minutes. Lets seen how it behaves.
12-05-2021 05:29
12-05-2021 05:29
@vishalw That sounds very strange. I charged mine yesterday afternoon and now over 12 hours later I'm at 86%.
Best Answer12-05-2021 09:42
12-05-2021 09:42
This happened to me too. I contacted support and the only thing they recommend was to fully charge then sync 5 or 6 times run the battery down and try again. Not overly confident that will work.
Best Answer12-05-2021 18:59
12-05-2021 18:59
@vishalw I got two Fitbit charge 5 at the same time. I and my mom are using it. My battery drains quickly but my mom's battery is holding good charge. I am using android phone Galaxy s20 and my mom is using an iPhone 12.
I am thinking that on Android there is all day sync force enabled but on iPhone all day sync is not enabled. Could that be the reason?
