01-07-2022 08:40
01-07-2022 08:40
Am I correct in my conclusion that NOT A SINGLE clock face option for the Charge 5 in the gallery of choices displays steps without having to tap the display to get that information? Just asking before I return it.
01-07-2022 12:00
01-07-2022 12:00
Hi @RoadHazard125 - I just installed the Slashed clock face to my Charge 5. Looks like it will show what you want. You can tap to scroll between different data but in my experience, once you tap to display steps, it stays there unless you inadvertently tap and change it. There are several other clock faces that behave the same way.
01-07-2022 12:04 - edited 01-07-2022 12:05
@RoadHazard125 - I just found another one you may want to look at. It’s called Ice Cream and the step progress is always on.
01-07-2022 13:10
01-07-2022 13:10
Best Answer01-07-2022 13:17
01-07-2022 13:17
Thank you! I installed it just now, and hope it will keep the screen I have it on. The “Continuum” screen I started with would NOT hold the display showing step count as it was supposed to, but maybe this one will. Fingers crossed, and thanks again.
