Charge 5 - Exercise Page - Yoga
ANSWERED
For FitBit Devs or Insiders,
Has there been any talk on adding "yoga" to the "exercise page" on Charge 5 or other Fitbit devices? If so, what's the time table for the update?
Thanks.
1 BEST ANSWER
Accepted Solutions
Welcome to the Fitbit community, @JBxx!
To add Yoga to the exercise page, you have to customize the Exercise Shortcuts on your Charge 5 first. To do so please tap on your profile picture in the upper left corner of your Fitbit app's Today page. Next tap the Charge 5 tile. Then tap Exercise Shortcuts. Now swipe one of the exercise shortcuts you don't need to the left to remove it. Next tap on the Plus sign in the upper right corner and select Yoga to be added to the exercise shortcuts.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2, Pixel 4a, Pixel 7
5 REPLIES 5
Stefan
Thanks Talahthas! On the "Exercise Shortcuts" page the only items that are available are: Run, Bike, Swim, Treadmill, Weights and Interval Workouts. At the bottom, it says all shortcuts in use. I also made sure I do not have an update pending. There is not a "plus" signs to add anything either. Do you have any further info on how to possibly add yoga?
@JBxx You need to remove one of your current exercise shortcuts first in order to see the + sign. You have to press, hold, & swipe to the left to remove one of the shortcuts. After you add Yoga, you can use the 3 bars on the left to re-arrange the shortcuts to show up in the order you prefer.
@RiekoC @Talahthas thanks to you both! That did the trick. Appreciate the assist. 💪😎
You're welcome, thanks for your positive feedback, @JBxx!
Stefan
