01-01-2023
11:50
09:08
DavideFitbit
01-01-2023
11:50
09:08
DavideFitbit
Hi
New to Fitbit, purchased the Charge 5 , the app draining battery on my phone , can not find anywhere in app to alter settings sync wise,
Contacted customer support they won't help as say it's my phone maker issue as phone battery. When it's not , as only started when fit app installed and currently used 20% of battery so far on Android 12
All I want to know is how do I alter settings to sync in app to stop phone battery drain .
As customer service would not assist at all
Moderator edit: format
01-03-2023
09:08
11:41
01-03-2023
09:08
11:41
Hi, welcome to the Fitbit Community forums, @Yorkshireguy.
Thanks for sharing that you've been having this inconvenience with your Charge 5 and that you already tried a few steps to try to resolve it.
Before considering other options, please check if the following settings are turned On or Off in your phone:
Background restrictions or limitations
Battery limitations
These settings should usually remain off to improve syncing and to receive notifications on your device. However, you can try to turn them on to check if you notice any difference on battery life of your phone. In addition, you can also try to uninstall and reinstall the Fitbit app.
01-03-2023
09:08
11:41
01-03-2023
09:08
11:41
Battery limitations
01-05-2023 12:55
01-05-2023 12:55
Thank you this seems to have helped
01-14-2023 09:47
01-14-2023 09:47
04-28-2023 17:13
04-28-2023 17:13
What helped? Restricting the battery usage or reinstalling the app?
04-28-2023 22:42
04-28-2023 22:42
Go to Apps & Notifications > Fitbit app.
Tap Background restrictions or Background limits and check if the setting Off.
Battery limitations
Go to Apps > Fitbit app > Advanced > Battery > Battery optimization.
Change the view to All apps.
Search for the Fitbit app and choose Not optimized.
This is what worked for me
05-10-2023 08:10
05-10-2023 08:10
Hi, it's good to see you visiting the community for the first time, @Nswecker.
Let me know if you continue to have the same problem or if you were able to resolve it with the steps provided earlier.
