Good to see you participating in the community for the first time @sdasgupta3
Thanks for sharing the inquiry regarding Charge 5 and I'm sorry to know that your device is not recording the information correctly.
If the GPS is getting disconnected during your activity, the Charge 5 may track different information for the the distance. Before considering other options, make sure to follow the steps suggested in this article.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. In particular, please make sure of the following:
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed in this article to complete a restart, as this has been useful for other users experiencing something similar.
Best AnswerThank you for your reply. The sky has been pretty clear and I walk along known routes with few trees. I will check the location setting and do the restart as you suggested.
