08-25-2023
04:14
05:00
08-25-2023
04:14
05:00
Hello good day, my charge 5 battery might have an issue, the power isnt lasting for more than 8 hours, and before it use to remain charged for 2 days, can i fix this? I dont want to lose my information when i am walking and it cuts off. Please help. Thank you so much.
Hello there, @FatbellyPearl. Thanks for the details provided in your post about the issue with your Charge 5.
If you haven't done so already, please make sure that you've followed the steps provided in this article to improve battery life in general, as this has been generally useful for other users. In addition, please complete a three pulse restart following the steps listed here below:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours.
Best AnswerMine will not hold a charge. The face comes back from black occasionally and it continues to start and reset on its own. Have done all the reset things and all advised steps. Fitbit losing its mind. Please advise
Best AnswerWelcome to the club of broken trackers. Nothing recommended will help. Expect your Charge 5 to die soon.
Best AnswerHello @FatbellyPearl
When my Charge 5 battery started to rapidly lose power, I restarted and recharged my device multiple times over several days. Eventually, this process got my device "unstuck" and the battery went back to lasting 6-7 days.
One of our users has a detailed post on all the troubleshooting steps they took which seemed to help with the rapid battery drain. Click here for the post: Possible fix for rapid battery drain
Hopefully, trying these troubleshooting steps will give you a similar positive result.
