09-02-2023
05:10
06:38
ManuFitbit
09-02-2023
05:10
06:38
ManuFitbit
My Charge 5 is set to auto GPS and will track a walk fine. However if I try to track a bike exercise it stops recording speed and location after about a minute, I stop the exercise and start a new one allowing GPS to get to the connected state it just fails again seconds later.
I also tried setting GPS to FB and also phone only, no change.
Rebooted phone (Android 13) and FB, no change.
GPS signal is fine as I can track a walk on the same route fine every time, this just affects tracking a bike exercise.
Any help gratefully appreciated
Best Answer09-02-2023 06:42
09-02-2023 06:42
It's good to see you participating in the community @Martin73.
Thank you for sharing the inconvenience that you are experiencing with your device.
As a first step, I'd like you check the guidance and all the recommendations that are listed in this article.
Please make sure that you've followed all the troubleshooting steps listed here below and that are also present in the article mentioned earlier:
If you still have trouble connecting to GPS or notice that your distance traveled seems inaccurate, try the following tips to allow your device to connect to GPS satellites:
In addition to the steps mentioned above, make sure to complete a restart procedure as well if you continue to experience the same inconvenience.
Best Answer09-02-2023 23:42
09-02-2023 23:42
Thanks for the reply, if I select walk or outdoor workout they work fine even if I actually cycle or walk at the time, so this a specific problem with logging a bike activity.
