09-02-2023
00:56
04:11
09-02-2023
00:56
04:11
Bought charge 5 and changed from charge 4. But this new clock does not track sleep. What to do? Already restarted it but did not help. Returning and changing to other vendor seems to only option.
Hi there, @mieitte. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
While reading your post, I understood that you just got the Charge 5, right? If so, please note since you just bought it, give the RHR a few days to settle down. It does some calculations, looking at heart rate throughout the day and while you are sleeping, so it might just not have enough data to give a reasonable value yet.
In addition to that, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Best AnswerHi MarreFitbit and thanks for the tips but they won't help me at all. Yes the new device is Charge 5. I had Charge 4 earlier and everything was working fine. Been wearing the Charge 5 since 30.8 so it should have been able to calibrate itself and collected enough data.
Here are the issues:
