05-22-2022 02:23
05-22-2022 02:23
Has anyone else had this issue?
All the other clock faces can be displayed in the 24 hour format, but as soon as I switch to the retro clock face it displays in the 12 hour format, even though the 24 hour option is selected in settings...
06:39
06:36
05-27-2022
06:39
06:36
Hi, welcome to the Community forums, @mohd16.
Thank you for sharing your inquiry about the Charge 5.
I've been using this clock face you mentioned and I was able to confirm that you can only see the time on a 12 hour format, as you mentioned earlier.
If you haven't done so already, I would recommend that you post this idea (24 hour format with this clock face) in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
Thanks again for sharing your feedback and comments about this.
I'll be around.
Best Answer05-29-2022 15:12
05-29-2022 15:12
Thanks, I'll give it a go.
06-03-2022 11:47
06-03-2022 15:33
06-03-2022 15:33
@DavideFitbit i hope you don't take is an offence or a violation of guidelines but please name a suggestion for Charge 5 that has been so far implemented.
