Charge 5: Short Battery Life
ANSWERED
It’s happening very often and it is frustrating. My Charge 5 just randomly turns off even if it is fully charged, and the only way to turn it back on is connecting to the charger which is very inconvenient if you don't have it on you.
1 BEST ANSWER
Accepted Solutions
Hi, welcome to the Fitbit Community forums, @Noelh15
I appreciate the information provided regarding the issue you're experiencing with your Charge 5.
If this is related to the battery, please make sure that you've properly charged your device. In addition and if the screen is completely black, make sure that you've also completed the restart procedure described here below:
  1. Connect your device to the charging cable.
  2. Press the button located on the flat end of the charger 3 times within 8 seconds, holding each press for about 1 second.
  3. Wait 10 seconds or until the Fitbit logo appears.
  4. If the device doesn’t restart, wait 15 seconds to try again.
74 REPLIES 74
This turns on the device but it will turn itself off again shortly
I have the same problem, contact custom service many times but they couldn't fix it
I have tried all options. Also charge 5 is fully charged, rebooted several times  cleaned several time as per instructions, it keeps shutting down and will only restart once attached to charger.
I am facing the same issue. Tried these steps but doesn't solve the problem.
This is happening to me now also. Has Fitbit provided any response yet?
I contacted customer support again. I was told it has become evident to them that the battery in the Charge 5 does not meet the needs of the device. They immediately sent me an email with a link to either get a replacement of my current device or 50% off a different one.
I contacted support also and they walked me through all the possible solutions but nothing has worked. Because my device is 1 year and 6 months old (6 months over the warranty), it is no longer covered by the warranty. So they offered me only 35% off a new device, no free replacement…kstande, was your device still under warranty?
Hi everyone, thank you for all the details that you've provided so far about this inconvenience with your Charge 5.
It seems that many of you have already contacted the Customer Support team for further assistance with this. In this case I do recommend that you continue the communication with them so they can let you know about the options available for you. If you still haven't contacted them, you can get in touch with them here to chat with them or to call them directly.
Thanks for taking the time to share your feedback as well about the warranty limitations. Comments from users are always helpful to continue improving the quality of products and services.
Big whoop! Doesn’t help if you can’t fix the problem.
I'm having the same issue.  It didn't start until the app update, so I thought it might be that.  It seemed like it was happening after I checked the app, but it just did it again and I had not opened the app today.  The only way to get it to come back on is to plug it in to the charger, and it says my battery is at 82%, so it's not because the battery is low.
Experiencing exactly same issue - so annoying…
I am having the same issue, everyday my Fitbit goes black and only way to recovery is to plug in the charger.   What is the resolution?
What happen when you have gone thru the restart program, sometimes several times a day, and the screen continues to go black or show the logo.  Do I need a new battery?  I have had this device less than a year and find it very frustrating.
Mine has been doing the exact same thing for about a month.  No fix or reset lasts more than a day
having same issue
I kept restarting an cleaning my fitbit charge 5. It is on version 57.20001.188.58. an it turns off when the battery is at the interval of 90to65.
Exact same issue for me.  Fitbit seem to have major issues, but no resolve.
I was told to change my clockface  - I am not sure what difference this should make?
