07-04-2023 08:06
07-04-2023 08:06
Hi. I've used the Charge 4 for about 8 years and just switched to the Charge 5, which I like a lot so far. But I have minor issue with the default display of the "Target" clock face. When I glance at it the focus is on heart rate. I'd like the focus to always be on Steps instead. Is there a way to change this? I realize I can always scroll to find the step count but I'd rather just see when I glance at the watch face. Thanks!
07-04-2023 09:19
07-04-2023 09:19
Hi & welcome @BriMaguire
I believe that Target clock face allows you to select which stat shows on the display. Tap the screen until Steps shows. Your steps stats should continue show until you tap the screen.
07-04-2023 09:19
07-04-2023 09:19
07-04-2023 11:02
07-04-2023 11:02
Hi Reiko! That's it. You are correct and I'm a bit dim, I guess. 🙂 Yes, just tap the watch face and it scrolls through all the default items.
Thank you so much! It was driving me nuts!
Cheers
Brian
Best Answer07-04-2023 13:45 - edited 07-04-2023 13:46
Hi @BriMaguire
Yay! I'm so glad I could help. And, I wouldn't say that you're a bit dim, rather just a user in a learning phase. 😉 Besides, it's not always easy to figure these things out.
