Charge 5 - Undoing water lock - screen is unresponsive
I used water lock to swim for 1/2 hour. Now the screen is blank and I cannot activate anything.  Any suggestions?
Moderator edit:  updated subject for clarity
1 REPLY 1
Welcome to the Fitbit community, @Soyson
To turn off water lock on Charge 5, you'll have to firmly tap the center of the screen twice with your finger. If you don't see "Unlocked" on your screen, please try knocking harder. If you're going to turn off this feature, your device's acceleration sensor will be used. This requires more power to activate than a normal tap on the touch display would be.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2, Pixel 4a, Pixel 7
