Welcome to the Fitbit community, @Rie829!
GPS reception may be hit and miss depending on where you're exercising. To better understand what might be impeding a good GPS signal, please have a closer look here:
How do I use GPS on my Fitbit device?
Hi @Rie829 Welcome to the community forums.
Thanks for the details regarding your Charge 5.
In order to have a better experience with the device, please:
Make sure that you have a clear view of the sky when you start the exercise. Environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites. If the signal is blocked, either because you're indoors, underground, or due to another reason, GPS won't work.
