08-19-2024
18:54
04:36
08-19-2024
18:54
04:36
My Fitbit is suddenly losing battery charge every day or two (like completely dead). I turned off the "always on" but that's not helping. It also displayed the incorrect date all day today, showing tomorrow's date instead of today's. Syncing is hit and miss as well. Any suggestions??
Hi there, @TracyStr. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is showing the wrong time and that the battery is draining quickly. I understand your concern, I will do my best to help you with this!
As a first approach, please bear in mind that as all rechargeable batteries age, they deteriorate to some extent and an older device will need to be charged more often than a new one. The best way of minimizing this effect is to avoid deep discharges of the battery. To maximize the overall life of your Fitbit device's battery, ideally keep it between 20-80%. Many people find that a daily battery boost works best ( e.g. giving it a 15 minutes charge while you are showering in the morning). In addition to the Always-On, keep in mind that there are other factors that may impact the battery life of your device. For more information, see Can I extend my Fitbit device's battery life?
Regarding the wrong time, may I know if you've experienced syncing issues recently? Is the connection between your Charge 5 and your phone good? Keep in mind that your Fitbit device uses the time of the device you're syncing with. If you haven't done so yet, I'd recommend trying the following steps in the order listed:
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
