07-01-2025
10:10
20:15
ManuFitbit
07-01-2025
10:10
20:15
ManuFitbit
The battery of my charge 5 is draining too fast and it takes now a lot more time to charge than it used too.
I charge it always on my computer and I havn't changed anything else. Right now it's stuck at 33% charging for more than an hour.
What can I do? I have checked other topics about battery drain but nothing seems to fix it.
Greetings.
Moderator edit: clarified subject.
07-01-2025 15:18
07-01-2025 15:18
Hi, @nchazarra charging via a computer is very slow at the best of times. Depending on your computer’s settings it may deliver little or no charge while it is in sleep mode and absolutely none during hibernation. I would always recommend using a wall charger as long as it is UL/CE certified. The charger you use for your cell phone is likely to be ideal.
Older batteries - and now the Charge 5 is an older device - will usually drain more quickly than when new, and may need longer to charge. How quickly batteries deteriorate largely depends on how they are used. Generally speaking it is best to avoid deep discharges and the ideal state is between 20-80% charged. For best results for very small batteries like the Fitbit charging little and often is ideal. Fifteen minutes or so on a wall charger each day should do the trick, perhaps with an occasional longer charge.
I hope this helps. Welcome to the Fitbit Community Forums!
07-01-2025 20:14
07-01-2025 20:14
Good to see you participating for the first time in the community @nchazarra.
Thank you for sharing with us this inquiry regarding your Charge 5.
Please confirm that you have followed the steps listed in this help article: Extend your Fitbit device's battery life.
Thanks for your help @Julia_G.
Best Answer07-02-2025 01:22
07-02-2025 01:22
Thanks for the welcome!
Yes, I have followed all the steps, that's why I'm really sad. I think the battery is already dying...
Yesterday I tried to charge it again but after many hours I was unable to charge more than 55%.
Best Answer07-04-2025 06:10
07-04-2025 06:10
this is not working , since the fitbit app updated my charge5 lasted only 3 hours
