12-13-2023
16:38
06:42
12-13-2023
16:38
06:42
When I got my charge 5 back in April, it would last for 5+ days. Now, I am lucky to get 18 hours out of it.
I took it off the charger this morning and it was 100%. Now, 12 hours later, it is down to 10%.
Anyone else have this issue? Is this a glitch or a feature?
12-13-2023 19:36
12-13-2023 19:36
Hi, @CG71 , as I am sure you are aware, all rechargeable batteries have a limited number of recharge cycles. How many you actually have varies a lot depending on how a battery is looked after.
Ideally, for longest overall battery life, your battery should be kept between about 20-80% charged always. Occasional deep discharges will do very little harm, but if you consistently wait to recharge until your battery is very low (below 20%) over time the battery will definitely deteriorate. Little and often is the best advice.
Many people have a good experience if they pop their Fitbit on the charger for 10-15 minutes every day, or a little longer, if necessary, to keep it topped up - perhaps while you are showering or getting ready for work, or in the evening watching TV or relaxing with a book. Following this advice I have several older Fitbits that still work well 3 or 4 years or even older.
Moving forward, I would recommend this regimen of a daily top up on charge, as you report that the battery is now showing some signs of deterioration.
You may find this help article , which discusses extending your Fitbit’s battery life, helpful.
Best Answer12-13-2023 21:24
