05-27-2024
18:30
04:35
05-27-2024
18:30
04:35
Recently, my Charge 5 started to drain pretty fast, and the battery does not report correctly. I went from about 50% to 31% in 7 hours with normal use (No gps, screen wake manual). When I plugged it to charge, it jumped from 31% to 52% instantly. Sometimes, it did not charge to 100%, but around 70% and when I restarted it, it jumped to 100%. This is my third Charge 5 from December, 2021. I bought my first Charge 5 in December, 2021. However, after about 6 months, it did not charge and the screen did not on even though it vibrated when restarting using charging cable. Since I was still in the warranty period, I got a replacement. But the same issue happened again after about 10 months of using. Therefore, I bought the third one. Now the warranty is over, and it has problems.
Does any body have the same issue?
Hi there, @Shin72111. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the battery of your Charge 5 is still draining quickly. I understand your concern, I will do my best to help you with this!
I've seen you contacted our Support Team just right after posting here and they've already assisted you. If you have any questions regarding the outcome of your case, please don't hesitate to reach out to our team again. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
