06-24-2024
10:18
10:35
06-24-2024
10:18
10:35
been wearing my fit bit for a year no issues... out of the blue the fitbit won't stay charged for more than an hour. No settings were altered. I have tried 3 press solution to reset but still having the same issue. Please give me a real fix?
Hi there, @Mnacca. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the battery of your Charge 5 is still draining quickly. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. Nevertheless, since you mentioned you already tried that, please confirm that you performed the restart as described below:
Best AnswerHello @Mnacca
When my Charge 5 started having rapid battery drain, I restarted and recharged my device multiple times over several days. As soon as I noticed the battery% had a big drop, I restarted my device then put it on the charger, often doing this multiple times in a day. This process eventually got my Charge 5 "unstuck" and the battery life went back to lasting 6-7 days. Although there's no guarantee that this will work, it might be worth a try.
