06-24-2024
04:29
04:51
06-24-2024
04:29
04:51
The watch already had battery issues like it will drain quickly
So all night I keep it on charge so I can use it in work
I did the rebooting with the charging cable but it did not turn on
i looked on the app and it turned off at 2am
Can u help me? 😭
Hi there, @ADIssues. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the screen of your Charge 5 is still blank. I understand your concern and how you must be feeling, I will do my best to help you with this!
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best AnswerThanks but I can’t change the clock face or do anything from the app since it can’t sync the watch 😭
Best AnswerHello @ADIssues
From user posts that I've read as well as my own experience, a single restart may not fix the problem. Some have had success by doing multiple restarts. One user reported that they did multiple restarts for 2 days which eventually got their Fitbit back to turning on & working. Although there's no guarantee that multiple restarts will work in your case, it might be worth a try.
If the multiple restarts don't work, you could contact Fitbit support (<-- click link). Continue through the process until you get to the option to call or message.
