05-02-2025
15:01
08:28
05-02-2025
15:01
08:28
My charge 5 is suddenly draining from 100% to 0 in 3 hours. Have latest updates done, and have tried a reset. Not changed any settings, and don't think it should drain this quick with gps on anyway. Any ideas please?
Best Answer05-03-2025 09:30
05-03-2025 09:30
Hi there, @lainryf99. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear the battery of your Charge 5 is draining quickly. I understand your concern, I will do my best to help you with this!
Since all the steps you tried didn't work, you have a Charge 5 and report that the battery doesn't last as expected, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
05-03-2025 10:34
05-03-2025 10:34
hi. thanks. I have completed the form.
Best Answer05-03-2025 10:38
05-03-2025 10:38
I have the same issue. Started last night
Best Answer05-03-2025 11:17
05-03-2025 11:17
Mine is also draining VERY quickly
Best Answer05-04-2025 00:11
05-04-2025 00:11
Mine is the same it started on Friday too.
