06-06-2025
05:17
06:12
06-06-2025
05:17
06:12
My charge 5 battery is starting to fail after just over 2 years. Feeling hacked off
Best Answer06-06-2025 06:19
06-06-2025 06:19
Hi there, @MrDisappointed. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that the battery of your Charge 5 is draining quickly. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend making sure that your phone's software version is updated. For more information, refer to Check & update your Android version or Update your iPhone or iPad
If you haven't done so yet, please try all tips and recommendations provided here Can I extend my Fitbit device's battery life?
Best Answer06-06-2025 07:01
06-06-2025 07:01
Same. First I lose battery, then the screen goes black even after charging. This has happened 2-3 times in the last couple weeks. I have charged it 3 times in the last 2 days and it runs dry in hours. It has the same settings it has over the last 2 years so, nothing changed there. I have done all the suggestions to fix these issues to no avail. I think it’s a goner. Sad that these are such disposable things.
Best Answer06-06-2025 07:36
06-06-2025 07:36
