01-16-2024
01:01
14:23
ManuFitbit
01-16-2024
01:01
14:23
ManuFitbit
Battery lasted 36 hours before August 2023. Then it lasts only one hour. When I am not using it and when I chrged it, it dies still in on hour. So sad because it is great device. Seems to be problem with other users FitBit charge 5 also.
Moderator edit: clarified subject
Hi @sinik. Welcome to the community forums.
Thank you for sharing the inquiry regarding this situation with your Charge 5. Sorry to know this.
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
