03-18-2023
04:33
06:32
03-18-2023
04:33
06:32
Best Answer03-18-2023 08:17
03-18-2023 08:17
A number of us experienced sudden loss of battery after updating to the latest firmware.
I suggest that you contact Fitbit support. They will walk you through a series of troubleshooting procedures. Once they confirm that none of the procedures returns your device to normal operation and if it's still under warranty, they should send you an offer to replace the tracker/pebble or a discount on a different Fitbit. If your Charge 5 is no longer under warranty, from what I've read they should send you a discount to replace your device. Note: the discount is on the full price even if the device is on sale in the Fitbit store.
My replacement Charge 5 is working fine and is back to lasting 6-7 days between charges.
03-19-2023 06:34 - edited 03-24-2023 09:53
Hi there, @Mccville. Welcome to the forums. Thanks for the details provided in your post about the issue with your Charge 5. I understand how you must be feeling
If you haven't done so already, please make sure that you've followed the steps provided in this article to improve battery life in general, as this has been generally useful for other users. In addition, please complete a three pulse restart following the steps listed here below:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours.
If the above doesn't work, please follow @RiekoC's advice and chat with us online or give us a call. Click here to get connected.
Best Answer03-23-2023 19:26
03-23-2023 19:26
03-24-2023 05:54
03-24-2023 05:54
@Mccville , any luck? I have been having issues with mine for quite a while now. I just completed the steps suggested and am hoping that it solves the issue.
03-24-2023 14:39
03-24-2023 14:39
