06-28-2023
20:10
04:35
06-28-2023
20:10
04:35
Received Fitbit Charge 5 for Christmas 2021 - BATTERY NOT HOLDING CHARGE NOW have only had for 1.5 years. Online advising FITBIT batteries are only lasting up to 2 years, Will not purchase another Fitbit!
Hi there, @rickdvskjeie. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5. I understand how you must be feeling.
If you haven't done so already, please make sure that you've followed the steps provided in this article to improve battery life in general, as this has been generally useful for other users. In addition, please complete a three pulse restart following the steps listed here below:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours.
Best AnswerHi
i have done all what was needed to correct the battery life sinds 14 juli this year my fitbit charge 5 makes trouble it needs to be on the the charger 2 or 3 times a day because it runs out off battery and my fitbit gets now a lot off trouble did everything but does not do anything anymore not tracking heart ect. and i still have the firmware 57.20001.188.58 dont now what to do anymore loved this fitbit and never had trouble with any of the charge series
pls fix this for us all thnx
Best AnswerHello MarreFitbit,
I received the Charge 5 this past Xmas and the charge does not last more than 18hrs.
I have tried all the recommendations in the forum without success. Please advise next steps and assume my Fitbit is still under warranty. (?)
Thank you.
Best AnswerHello & welcome @PHayes12
Sorry to see you're having problems with your Charge 5 battery.
When my Charge 5 battery started losing power very quickly, I restarted my device multiple times and kept recharging it over several days. My Charge 5 finally became "unstuck" and the battery went back to lasting 6-7 days. Hopefully, you will have a similar experience.
If this doesn't work, I suggest you contact Fitbit support, especially since your Charge 5 is still under warranty. Click here for links to contact them by chat, phone, and direct message: Fitbit support
