Charge 5 battery is draining too quickly
My Charge 5 is not staying charged since the update was done what can be done
2 REPLIES 2
Welcome to the Fitbit community, @Chevybear88!
Sad to hear you're having issues with your Charge 5. As a first attempt to get things fixed I'd suggest restarting it. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 5 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'd like to point out that it sometimes requires more than one attempt to restart Charge 5. So, before throwing the towel, please give it another try.
There also might a problem with charging itself. So please have a closer look here to hopefully get a hint what might solve your issue:
Why isn't my Fitbit device's battery charging?
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
Hello & welcome @Chevybear88
When my Charge 5 battery kept losing power faster than usual, I restarted my device multiple times over several days and kept recharging it. It finally went back to the battery lasting 6-7 days.
 I used the Settings menu on the Charge 5 itself to keep restarting my device:
  • Swipe down from the clock face until you see the Settings tile (last one)
  • Tap on Settings
  • Swipe up until you see Restart Device (last option)
  • Tap on Restart Device
  • Swipe up to see the Restart blue tile
  • Tap on Restart
  • The screen will go black for a few seconds, then it will display the Fitbit logo
  • When it finishes restarting, you should see the clock face
Or you can follow the instructions that @Talahthas provided
