06-17-2024
00:08
03:19
06-17-2024
00:08
03:19
The percentage of battery is always misleading. Always changed, quickly become full or empty. It even could not simply be a reliable watch now. Very frustrated. Really bad product in the world.
Best Answer06-17-2024 00:14
06-17-2024 00:14
hi eddy, it looks alot like your battery is faulty.. even worse than my 2016 fitbit blaze.. so theres a defect in your Fitbit. contact official Fitbit support, and they will give you a discount on a charge 6, or if your device is in warranty you can go to fitbit for repair. You can also buy a replacement battery and open the device. keep in mind opening it voids the warranty. its also a difficult job.
06-17-2024 03:23
06-17-2024 03:23
Hi there, @EddyHK. Welcome to the Fitbit Community Forums. I'm sorry to hear that the battery of your Charge 5 is draining quickly. I understand how you must be feeling. We're here to help you!
As a first approach, I'd recommend to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. Nevertheless, since you mentioned you already tried that, please confirm that you performed the restart as described below:
@finleyhenry7 Thank you for your input and advice!
Best Answer06-17-2024 04:17
06-17-2024 04:17
So I've switched everything off on my charge 5, and I mean everything possible.
It was working very nicely until about 3 weeks ago, when it started draining with 3-4 hours.
It's 2 years old and I love it, however having seen all the similar complaints on here I'm nervous about a new purchase.
Will I get a discount code? if so how much?
Best Answer06-17-2024 10:54
06-17-2024 10:54
When my Charge 5 started having rapid battery drain, I restarted and recharged my device multiple times over several days. As soon as I noticed the battery% had a big drop, I restarted my device then put it on the charger, often doing this multiple times in a day. This process eventually got my Charge 5 "unstuck" and the battery life went back to lasting 6-7 days. Although there's no guarantee that this will work, it might be worth a try.
