04-17-2022
16:10
07:38
DavideFitbit
04-17-2022
16:10
07:38
DavideFitbit
Just bought a Charge 5. Have set it up and synched to app.
Cannot get alarm to ring! I punch in the time to wake and get “alarm set” reply, however alarm never rings, vibrates, etc..
Previous Fitbit used to set alarm on the app, appears not to be the case with Charge 5.. what am I doing wrong?
Thanks!
07:37
09:06
04-19-2022
07:37
09:06
Hi, welcome to the Fitbit Community forums, @Charge5alarm.
Thank you for sharing that you've been experiencing this problem with your Charge 5.
Before considering other options, please try the following steps:
Hope this helps, I'll be around.
04-19-2022
17:42
11:36
DavideFitbit
04-19-2022
17:42
11:36
DavideFitbit
Thanks for the advice! I set the alarm Sunday for Monday and it worked, Monday for Tuesday it didn’t even though I got the blue check mark.. will try swiping right tonight and see if that works, if not will turn off device tomorrow..
Thanks again!
Moderator edit: removed personal info
11:37
09:06
04-26-2022
11:37
09:06
@Charge5alarm Thank you for sharing this update! Let me know how it goes in the following days.
I'll be around. 😁
