08-20-2022
08:01
07:39
DavideFitbit
08-20-2022
08:01
07:39
DavideFitbit
I don't know what one of the icons is on my Charge 5. I get the shoes (steps), the heart (heart rate) and the upside down tear with a dot (miles). There are three arrows pointing up with a one digit number to the left. What is that?
Moderator edit: format
09-10-2022 07:39
09-10-2022 07:39
Hi, thank you for your inquiry regarding the icons on the clock face of the Charge 5, @SunsetRunner.
The ones you mentioned earlier are all correct, steps, heart rate and distance. The little flame would be for calories and the three arrows pointing up would be for Active Zone Minutes. You can also check the stats included with each clock face when you go to the Fitbit app and you see the description available for each clock face option. Let me know if you have other questions.
Hope this helps, I'll be around.
09-11-2022 10:15
09-11-2022 10:15
09-14-2022 12:17
