06-19-2022
11:40
07:24
DavideFitbit
06-19-2022
11:40
07:24
DavideFitbit
My Charge HR 5 crashes about once a week (I get the 5 small dots or it freezes) is this due to the clock face I'm using and switching to a different one may work better ?
I'm also not seeing any active minutes increase when I'm cycling. I can see my heart rate is up but when I'm done, active minutes have hardly changed, this didn't happen on the HR 4. Is this expected or some kind of bug ?
My HR 4 worked better and I'm surprised the crashing issue hasn't been fixed by a software update.
Hi, welcome to the Community forums, @alihut67.
I appreciate all the information that you've provided about this inconvenience with your Charge 5.
If you haven't done so already, please try these general recommendations that are usually helpful with any type of display issues:
Regarding the active zone minutes, these are based on your heart-pumping activity throughout the day. The restart procedure could be helpful with this as well, but I also recommend that you follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading.
Hope this helps, I'll be around.
