04-10-2022
07:39
12:27
LizzyFitbit
04-10-2022
07:39
12:27
LizzyFitbit
My Charge5 stopped refreshing daily data on April 6. It’s now has enormous data totals from several days. What do I do to refresh it?
04-11-2022
12:30
08:29
04-11-2022
12:30
08:29
Hi @forester60, and welcome to the Community Forums.
Thanks for letting me know about your Charge 5. This is odd and if you haven't done so, try restarting your tracker to refresh its performance, syncing with the Fitbit app and monitoring its behavior in the next days. Your tracker should start tracking your stats from zero after midnight. If by any chance the issue persists, please let me know so I can continue helping you with this.
12:30
08:29
04-11-2022
12:30
08:29
Best Answer04-11-2022 13:02
04-14-2022
15:10
08:14
04-14-2022
15:10
08:14
Hi there, @forester60.
You're welcome! Thanks to you for getting back and I hope your Charge 5 is now working correctly. In case you have some spare time, you can check out our Health & Wellness board where you will find great tips and encouragement from other members. Happy stepping! 😎
05-02-2023 07:32
05-02-2023 07:32
Hello,
I see this thread is a ywar old but trying anyway 🙂 My Charge 5 started having this problem last night. At 1am, it had not reset. I’ve restarted it twice and it is still showing yesterday's data. It also can't sync on my phone. I'm going to try unpairing it and also logging out from the app. Any other suggestions would be greatly appreciated!
05-02-2023 10:29
05-02-2023 10:29
Hello, I have a Fitbit Charge 5 as well, and this issue started happening to my Fitbit. I’ve tried restarting it and syncing to the app, but it’s still showing my step count from yesterday…
05-02-2023 12:08
05-02-2023 12:08
Glad I'm not the only one.. I feel like it is a software glitch. When I tap the home screen to see the different screens, like heart rate zone, total steps, calories, etc, the progress bar on the left flashes orange which didn't happen before... but it not a tech person so that could just be coincidental. I'm going to try a "long reset" using the button on the power cord as suggested elsewhere from a Google search. Will post if any luck 🙂
05-02-2023
12:45
07:57
DavideFitbit
05-02-2023
12:45
07:57
DavideFitbit
Re: fitbit not resetting at midnight...Fixed it!! I plugged in my fitbit charge 5 as if to charge and pressed the reset button on the charger, first held it for 30 secinds and nothing happened so then I pressed it off/on about 6 times. Then tapped the screen and it showed the battery had drained down to 5% (from about 80%!) so I left it to charge and when I came back 30 mins later, it was at 50%, had reset all counts, and is working properly now. Hope this helps anyone else for whom the simple "restart" solution also did not work.
@adrianefit Check my post below. Fixed mine, hopefully this will work for yours too🙂
05-03-2023 09:41
05-03-2023 09:41
Thanks! Mine ended up resetting after I walked around for a few minutes while wearing it. My step count from yesterday was still showing this morning until I synced it to the app, so it does seem like an intermittent thing that resets under certain circumstances. If I run into the issue again, I'll give what you did a try.
05-09-2023
08:27
12:38
05-09-2023
08:27
12:38
Hi there, @adrianefit. @SunsetRunner Welcome on board.
Thanks for joining this thread and your efforts while troubleshooting your Charge 5. I'm glad you got this sorted out and I'm sure your suggestions will help other members visiting the forums.
By the way, let me invite you to visit our Health & Wellness board where you can make new friends, find inspiring stories and start your own topics. Have a good one!
