11-04-2022
07:22
06:10
DavideFitbit
11-04-2022
07:22
06:10
DavideFitbit
I know this is an issue in the past. I’ve noticed it happening again. Charge 5 appears not connected in Bluetooth, which means I have to get Bluetooth to forget the device then pair again.
Charge 5 is a disappointing device. This is my replacement Charge 5. First Charge 5 was returned.
Best Answer12-09-2022 09:18
12-09-2022 09:18
@debsfit2021 Thanks for sharing this update and all your feedback about this.
Let me know if you continue to experience the same issue after you try to set up your device again to your account.
I'll be around.
Best Answer11-25-2022 06:10
11-25-2022 06:10
Welcome back to the Community forums, @Choccupcake.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
As you mentioned earlier, some other users have shared they're experiencing something similar. The team is aware of this problem and they're working on a resolution, but we haven't received other updates for the moment. If you haven't done so already, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
I'll be around.
Best Answer11-25-2022 08:38
11-25-2022 08:38
I have same problem and now won’t even connect at all. I’ve reloaded app
did everything mentioned above. I’ll try again but not finding my Charge 5 so it can’t be added to my phone again and can’t track
12-09-2022 09:18
I'll be around.
12:04
07:17
DavideFitbit
12-09-2022
12:04
07:17
DavideFitbit
Thank you! I’ve switched to an Apple Watch
The Charge 5 is not reliable for me.
Moderator edit: format
Best Answer12-24-2022 07:17
12-24-2022 07:17
@Choccupcake You're welcome. I'm sorry to see that it wasn't possible to resolve the problem and that you had to change to a different brand.
Thanks for sharing your feedback and your experience with this.
