12-13-2021
19:36
13:38
DavideFitbit
12-13-2021
19:36
13:38
DavideFitbit
hello, my Fitbit does not show the pairing code, it just goes black, please help me :c
12-15-2021 13:37
12-15-2021 13:37
Hello, welcome to the Community forums, @izzaak488.
Thank you for sharing this information about the inconvenience you've been experiencing with your Charge 5.
Before considering other options, I recommend that you try restarting the device using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
Then try to complete the set up process again to check if the pairing code is shown on the display.
Hope this helps, I'll be around.
