01-21-2024 13:39
01-21-2024 13:39
My charge 5 completely dies when the battery is showing 49%. When I put it on the charger it resets.
01-27-2024 09:30
01-27-2024 09:30
Hi @JHouleVeinot. Welcome to the forums.
Thank you for sharing the inquiry regarding your Charge 5. Sorry to know about the inconvenience experienced.
If you haven't done so already, please try to complete a restart procedure following the steps listed here below:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
