07-13-2023
11:50
05:05
07-13-2023
11:50
05:05
My charge 5 lost its screen display a month ago. Every time I tapped on it nothing happened. I finally got it fixed by resetting it. However for ages the notification on adding a card for Fitbit pay would come up, several times an hour. It went away but my better died today & when I did a charge it came back… 40 times a minute!!! It’s incessant. I tried the reset & now the Fitbit keeps going on & off. When it’s on the screen is frozen.
Is anyone else having these issues? The watch was perfect for 11 months & for the past month I’ve g go ad nothing but trouble
07-14-2023 11:20
07-14-2023 11:20
@Duffgirl Thanks for getting back!
To better assist you, would you mind sharing with me the exact message you're getting on your Charge 5? Is it stuck on "Set up Wallet"? If so, please note this screen will appear when opening the wallet app on your Fitbit device by either tapping on it or with left button to access to the shortcuts. While it's not possible to delete the wallet app, please give a try to the following steps to reconnect your watch to your account:
07-14-2023 05:09
07-14-2023 05:09
Hi there, @Duffgirl. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issues with your Charge 5 before reaching out.
To better assist you, please make sure you've restarted your Charge 5 as described here.
If the restart doesn't work and your Charge 5 doesn't vibrate during the restart process, please follow the steps below:
07-14-2023 10:57
07-14-2023 10:57
07-14-2023 11:20
07-14-2023 11:20
07-19-2023 08:04
07-19-2023 08:04
Hi there,
Unfortunately this didn’t work! It’s so annoying and my battery only lasts less than a day from a full charge. This is the message I keep getting - hundreds of times a day 😑
“Go to Fitbit mobile app and add card to your wallet”
