11-13-2024
09:04
06:32
LizzyFitbit
11-13-2024
09:04
06:32
LizzyFitbit
Fitbit Charge 5 worked up until yesterday midday (Nov. 12, 2024. Was charged to over 50% but started showing blue logo that would flash every 10 seconds. I have done everything suggested in the Forums to recover, and none have worked. This included an old trick (suggested) regarding placing in the freezer to restart the chip. Now, it is dead.
I have been a loyal Fitbit user since 2015. Many models + upgrades. One previous model died and was forced to upgrade. Most, I just wanted upgrade. The Charge 5 favorite thus far. Google upgrades caused sync issues a few months ago, but was fixed (and w/help from online tech). Charge 5 now dead. Reason to continue with Fitbit is needed.
12-07-2024 06:47
12-07-2024 06:47
Hi there, @WolfPackMac.
I'm sorry that you've gone through this situation, and thanks for the steps tried as well as your loyalty toward Fitbit. While you mentioned that your Charge 5 is dead, may I know if you see a green light on the back or if you feel a vibration when pressing the button?
If not, even though you've tried some steps, please give a try to the following in the given order:
12-07-2024 06:47
12-07-2024 06:47
12-07-2024 15:55
12-07-2024 15:55
Best Answer12-19-2024 10:37
12-19-2024 10:37
Thanks for your thoughtful post. I understand where you're coming from about having this experience and I apologize for the inconvenience this has caused. Our team is constantly working to enhance our products and the input we receive from all our members is a big part of the process.
I'd like to clarify that the issue with the top of the food screen has been fixed with a new Fitbit app version. If you haven't done so, please install it on your phone to check if everything looks good on your end. Regarding your other reports, I'd encourage you to share them in a different thread so we can prevent any confusion and so you can receive more assistance.
Once again, I appreciate your feedback and please know that you're always welcome back to the Fitbit family if you change your mind.
Best Answer12-19-2024 12:43
12-19-2024 12:43
I have the same issue. I let my fitbit run out of battery and now nothing i can do will turn it on. Ive left it on the charger for hours, cleaned the device, cleaned the charger, tried different outlets, did all the repetitive button pushing, etc, but no signs of life at any point. Any other ideas?
12-19-2024 20:22
12-19-2024 20:22
Charge 5 is trash . Fitbit is not helpful either. We all know the issue with fitbit charge 5 getting bricked after the update. Same happened to me . Not turning on . Customer service won't help. All they say is we are sorry to hear this . They say it is out of warranty so we cannot replace. But to begin with this issue is Fitbit's issue. Bad software updates is the reason for my bricked watch. Will never buy this brand again. Complete waste of money. My case is still open and I know they would not help
12-20-2024 05:16
12-20-2024 05:16
Mine died yesterday while swimming. Purchased 15 months ago. I called support, and a rep had me clean it, attempt to restart it, try charging in a different USB cable, etc. Nothing will revive it. Was offered 50% off purchase of a new one, but the discount must be used on the Google store applied to full retail price. Fitbits are discounted by 25% right now, so effectively just another 25% off.
