05-19-2024
14:17
06:52
CrisVillaFitbit
05-19-2024
14:17
06:52
CrisVillaFitbit
Charge 5 quit working, won’t reset or hold a charge. Have tried resetting, cleaning and waiting a full day for it to try to grab a charge. What else can be done? It is less than a year old
Moderator edit: edited title to clarity.
05-20-2024 06:56
05-20-2024 06:56
Hello, @Mcal57 and welcome to the Fitbit Community.
Thanks for letting me know about this situation in regards to your Charge 5 not charging.
Can you answer the following, please?
- Are the green LED lights in the back of the Charge 5 on?
- Does it vibrate when you plug it into the charger?
- I recommend you to follow the steps here.
Let me know how it goes.
Best Answer05-20-2024 08:03
05-20-2024 08:03
05-20-2024 10:07 - edited 05-20-2024 10:08
Hello @Mcal57
Since you've tried the recommended troubleshooting steps without success, you should contact Fitbit support (<-- click link). They will likely have you repeat the troubleshooting steps to determine if your device is defective. If they confirm that your Fitbit is defective and your device is still under warranty, they should let you know what are your options under warranty.
Best Answer05-21-2024 16:27
05-21-2024 16:27
The warranty option isn't a solution for those of us out of warranty who experienced a bad defective firmware update! How will Fitbit/google fix this?
Best Answer05-23-2024 06:51
05-23-2024 06:51
I received the replacement and am content with the process. Thank you
