02-18-2024
12:07
02:51
02-18-2024
12:07
02:51
Battery had gotten very low. The date and time are now wrong. How do I reset time and date?
Best Answer02-18-2024 13:20
02-18-2024 13:20
Hello @Stripes14
Your Charge 5 should be getting the time & date from your phone when you sync your device in the Fitbit app. Have your tried restarting your Charge 5?
If restarting didn't work, you're probably having problems syncing.This help article has the recommended troubleshooting steps to try : Why won't my Fitbit sync? (<-- click link)
Hopefully, this works to get the date & time fixed on your Charge 5. If not, please let us know.
02-18-2024 13:20
02-18-2024 13:20
Hello @Stripes14
02-18-2024 16:38
02-18-2024 16:38
02-19-2024 10:40
02-19-2024 10:40
Hi @Stripes14
Thanks for letting us know that syncing worked to get your Charge 5 back to showing the correct date & time. I'm glad it was a relatively easy fix.
Sometimes Fitbit devices act up when the battery gets to very low levels. Often, doing a manual sync or restart after the device is charged back up works to get it back to normal.
